winchendonsprings
I am going to try to make this simple and easy to answer.
I am looking to root my eris.
1. I was running a leaked 2.1 and I received the july OTA update yesterday. This means I can now root, correct? The July update was an official full operating system update, right? If the answer is no, than disregard the rest of this.
2. The main reasons I want root are speed and the ability to uninstall and strip down the extra crap I don't need.
I'll want to uninstall -
-Mail, I'll keep gmail app. I don't need 2 apps of the same.
-Peep, footprints, quickoffice, stocks, teeter, etc.
-I definitely don't need Sense.
So if the ROM I choose has these by default I can strip them out correct?
3. I don't need a fancy ROM to start with something simple and stable. Is the plain vanilla ROM for me?
4. Recommendations or anything I should know? I am a linux user and relatively comfortable doing terminal work.
