Root Help me choose a ROM!
nsmetana
Hey everyone!
This is my first post on these forums, so my apologies if it's in the wrong place.
But basically my question is just about which ROM I should use. CELB Froyo 1.9 or Cyanogen Tazz v6? I've heard great things about both, but I figured you all would know better than I!
So, which one and why?
Thanks for your help :)
Oh, and really quick, do both ROMs automatically overclock the processor?
Yes, the working camera is definitely a plus...
Do you have any idea which one is faster? As in, which one lags less?
OK, cool, I think I will be trying that one then.
And just curious, does it automatically overclock my processor when I flash the ROM?
I don't know what kind of power management is built in, but on other ROMS that came overclocked I definitely noticed a difference with aggressively power-saving setcpu profiles.
I use 245/245 screen off and 245/710 screen on. no unlock stutter that i've seen so far.
While the froyo is nice, you might try a 2.1 based rom as well. Im using a 2.1 rom and it runs circles around the 2.2 roms I tried.
