Root Help ME GUys:((
japhon123
[13:51] <japs> hi fellas
[13:51] <japs> i need your help:(
[13:52] <japs> i flash new rom
[13:52] <japs> then and install themes
[13:52] <japs> then when i got rebbot safe mode then always pop out edit text
[13:52] <japs> how i can flash again
[13:52] <japs> cant flash
[13:52] <japs> zzzzzzzzzz
[13:52] <japs> hope someone help me
Can you boot into recovery by holding volume down whilst powering on? You should be able to boot into clockwork and restore the backup you took before flashing the theme?
Nothing personal here Japhon and I can reassure you that we'll try our damndest to assist you. However whatever that is you've posted it isn't making too much sense or giving us much to go on.
We need:
1. Name of the ROM you're using (+link if you can)
2. Link to the theme you're trying to apply
3. Translate: then when i got rebbot safe mode then always pop out edit text
4. Can you still access recovery using vol- and power together and if so did you do a backup before flashing the theme?
El P said:
HaHa Stu FTL you too slow b*tch!
