Root Help me? Need an idiot proof guide to rooting.
seymour71
Hi guys/gals, hope one of you clever people can help me.
I have a HTC Hero on T Mobile (UK) and the build number is:
2.73.110.26
After doing a little reading on here and other forums, I think I would like to root this, in order to speed it up and remove programs I'm never going to need. I have tried the easy one click program thingy, that didn't work. I have read a little about the 'goldcard' method, but I'm not overly technical, and that looks complicated.:o
Is that now my only option?
Really..that method using instant root did not work?
Some T-Mob users said it worked for them.. weird.. I will try and get something done for the T-Mob guys ...
I would just like to add that flashrec/instantroot do not work for me either.
T-Mo UK G2 Touch running 2.73.110.26
I have researched this and the only method that seems to work is to downgrade the ROM via the Goldcard method.
Ok, i'll give it a go then (crosses fingers)
One thing before I start though, the guide on xda developers asks me to download something called qmat, but the link is broken - it now links to something called PSAS. Will this still do the job?
Nice one - thanks. Can I use that with the PSAS program then?
Also, with reference to this instrcution:
"Use adb to run this command"
What is adb? Sorry for all the questions, I am a complete noob on Andriod, and I really don't want to screw my new phone up!
You do not need QMAT/PSAS software if you follow the link I mentioned earlier or this:http://revskills.de/pages/goldcard.html
It automates steps 6-9 in goldcard procedure. The only thing you need is Hex editior.
To know and how to set up "adb" follow this link:
How To: Set Up ADB/USB Drivers for Android Devices | The Unlockr
ADB is Android Debug Bridge. It allows you to send commands to your phone. You will need to install the Android SDK in order to use the adb commands listed in the Goldcard tutorial.
If you're struggling with the guide you're using, may I suggest this one-
How To: Downgrade Your HTC Hero So It Can Be Rooted (Updated 02.05.10) | The Unlockr
It links to this page - How To: Set Up ADB/USB Drivers for Android Devices | The Unlockr
which tells you how to install the SDK.
Edit - vjprakashbe beat me to it, but I still suggest using The Unlockr's Goldcard guide :-)
Cheers guys, thanks for all your help - this is a great forum!:D
I will give this a go this evening, and doubtless i'll post more questions along the way!
cheers.
Told you I'd be back.:o
I have followed the excellent guide at above at Unlockr, everything has gone fine but when I'm trying to install the Hero RUU, I get the following message:
"Error 140 Bootloader version error"
"the ROM update utility cannot update your android phone"
"please get the correct ROM update utility & try again"
Just noticed on the Unlockr guide that there is an alternative RUU, so i'm downloading that at the mo.
After this is donr, and it hopefully works, Am i right in thinking I will then be able to gain root access with the one-click procedure?
Ok guys, so far so good, got root access etc using instant root, and copied & used flashrec & titanium backup. But when I get to this stage, as per the sticky above:
Are you sure you're using the most up to date recovery image?
I believe the one most people use is Amon Ra 1.62, which is linked to in the sticky. Here's the link to it again -
[Recovery ROM] [07-Mar-2010] RA-hero-v1.6.2 - xda-developers
If not, I suggest that you flash that recovery image instead of the one you're using.
If you are, you should see this-
If that is not the menu that you see, I suggest you reflash the recovery image using Flashrec.
Hi mate, yes I got all files as per the sticky above.
one step that did confuse me is this one though:
5. Open flashrec. Then, Back up your recovery on first screen then in address bar put "/sdcard/(ur amonra recoveryname with .img without ) and press flash
what ahould I be putting in the address bar? just "/sdcard/" or something else?
Assuming you haven't renamed the recovery image-
/sdcard/recovery-RA-hero-v1.6.2.img
:oDoh, I'm sooooo stupid. Thanks, that worked a treat all done now. Now to start the real tinkering!
Anyone know how i can get rid of that footprints program?
Hi there, i'm in the process of rooting my G2 as well and need a bit of help. I've trying to follow the unlockrs goldcard guide and keep getting stuck.
I've installed the sdk and htc sync, when i type in the commands
cd\
cd AndroidSDK\tools\
adb devices
once ive typed this in ( im using win7) i get a device number under list of devices attached, it starts with HT98 and is about 12 digits long.
Following the unlockrs guide i enter the code into http://hexrev.soaa.me/ but it says that its the incorrect length?? ive tried the other website somebody mentioned above http://www.andyappz.com/cid.php, this one gives me a CID.
I've then tried entering this CID in http://revskills.de/pages/goldcard.html but here it also says that its an incorrect CID.
I'm now a bit stuck, can anybody help please? am i doing something wrong?
cd\
adb devices
Following the unlockrs guide i enter the code into Soaa.me - (write down, copy, paste, and then) One-click hex reverse for GoldCard creation but it says that its the incorrect length?? ive tried the other website somebody mentioned above Gold Card Help v1.1b, this one gives me a CID.
I've then tried entering this CID in Free G1 goldcard generation ! but here it also says that its an incorrect CID.
I'm no expert as I haven't had to use the goldcard method, but from what I understand from quickly looking at the guide, I think you might be putting the wrong number in.
instead of doing:
adb devices
Which just lists devices connected, I think you need to do:
adb shell cat /sys/class/mmc_host/mmc1/mmc1:*/cid
Use what it gives you instead of the device code starting with HT98.
Hope that works for you.
