Root Help me pick a STABLE rom please!
Is there any stable roms for the Incredible 2? I've been using all the AOSPs and they ALL have the same problems and I can't take it any more. I realize these devs do this stuff on the side but I need a reliable phone. So is there any reliable roms out there?
I'm thinking about switching to a sense Rom. I was thinking Incredible 2 Mix or beatmod cyansense? But I really don't know what is a good rom. I need Speaker phone with Headset to work, GPS is a must!, Gmail must SYNC and in call volume must be loud like stock.
http://androidforums.com/incredible...ncredible-2-faq-roms-latest-update-9-2-a.html
Thanks for any help.
MIUI is the most stable for me, but the in-call volume is very quiet, that doesnt matter for me cause i usually use a headset. the most stable sense roms that ive found are incredible sensation, virtuous unity, or the desire s port. those roms you said are great and very stable too, but i like sense 3.0
If you are wanting Sense, I agree with mclovlein. Virtuous Unity us, by far, the best out there. MMS is a very simple fix and you are good to go.
If you are wanting Sense, I agree with mclovelin. Virtuous Unity us, by far, the best out there. MMS is a very simple fix and you are good to go.
I was looking into the Virtuous but What is that Patch that I'm suppose to also install? That part makes me a little nervous
Miui with the Tiamat kernel is very good. The custom kernel makes the in call volume very close to what it is with the stock rom.
ive had trouble with the tiamat kernal draining my battery very fast, but it was probably something i was doing. ill flash that tonight
Yes I've used MIUI with Tiamat. The incall volume is still not acceptable to me but yes it does help greatly. But also the GPS is backwards and the speaker phone with headset doesn't work. kind of a deal breaker for me. I really hope we get someone that can fix these issues on AOSP. I loaded the Incredible 2 Mix rom and It has been really nice so far but I REALLY REALLY miss CM7. there is nothing like vanilla android.
