Root help me please unroot
phil99
I have searched for two days now and nothing seems to help, i rooted my phone using unrevoked 3 and now i want to unroot it. I have reinstalled HTC Sync on my pc and tried to conect my phone but keep getting an error msg on my phone
Unable to find HTC sync
Any ideas and am i going about this the correct way
I just used unrevoked 3, and didnt change anything else, sorry if this is very vague but im new to all this
2 reasons might be giving it to the wife and i like to know how to do this if i get a problem with the phone and it needs to go back
What do you mean? That link is just different links to the RUU on different download sites - choose any of them
ive selected fastboot abd connected the usb cable, fastboot usb is in red at top, do i select bootloader
I cant do this process due to some usb problem on windows 7 64 bit
htc sync port is not responding
Rename the RUU "PB99IMG" using caps, put the file in the root directory of your sd card. With the phone off, press the down volume button and the power button, until the screen comes on.
Let the phone do its thing.
Chances are the original file was the actual PB99IMG.zip with the full version name, not an RUU - check the original file name again in the drop box
He might've extracted it out, tbh it's easier to flash a ROM from the PB99IMG than an RUU so I reckon he did it for the ease
