Help Me PLease
I Need help my phone has a slow start 10 minuts and when it powers up it says sorry! Process system not responding force close wait and then restarts what can i do ???
Factory Data reset through stock recovery. All data will be lost doing this but your phone will be back to like new, software wise.
Also you must uncheck back up my data in the privacy menu in settings before the reset or the corrupted files may be restored.
Settings>privacy>back up my data & settings>uncheck back up my data
Next:
Perform factory data reset.
If you can't access setting menu pull the sd card out and then do a reset with the hard keys. The back up data is saved to the sd card.
Next:
i did the reset but i couldnot use the phone cuz it's shutting down on its own
