Help me please
Vishal911
Hi guyz im new 2 androidforums
I have a serius prob actual i have karbonn a1(clone of zte n721and also have same hardware and software of huawei pulse mini and huawei u8150) problem is that my device is stucked on boot logo and nothing is working like i tried to go into recovery mode and also in bootloader mode but no luck. also tried from pc with adb and fastboot but it also not worked (whenever i connect my phone to pc it automaticaly detected as adb interface)i also installed usb drivers correctly n still no luck
This happend when i tried to flash recovery n boot image via terminal emulater... when it giving me out of space error i rebooted my cell n this happend.... plz plz plz help me guyz
Thanx 4 ur reply bro
Yes i tried this when i type this command i get device not found error. but whenever i connect my cell it detected as android sooner adb interface or sometimes android adb interface
It seems as if your phone is hard bricked, if you cant enter clockwork mod or recovery mod you cant try and re-install your stocked rom "if you backed it up" but anyway even if you do get another rom for your phone, you if you cant enter one of those places above you basically have a useless phone sorry.
Ohhhh thats so bad :-(.... anyways i want to ask u 2 questions
1- why i got out of space error when i tried to flash image files
2-and why im unable to go into cwm or stock recovery mode even after succesfuly flashing cwm when my mobile is normaly running coz whener i tried to go in recovery mode my cell stucks at zte logo(when my phone is NOT bricked)
Ciao guyz ho un problema ho bisogno di aiuto con il mio samsung galaxy s 2 quando cerco di scaricare parete il download ma arrivato al 95% mi ci questo( download di non riuscito a causa di un errore.(497) cosa devo fare chi mi aiuta grazie
hey guys!
i too have a karbonn a1
i have managed to root it
now i want to upgrade its android version from 2.2 to 2.3
i checked out the cyanogen website to see the available mods for my fone and as expected, i found none.
is there i way i can upgrade my phone???
p.s guys please be easy on me. i am just a tenth grader with not much techno knowledge
DOWNLOAD FROM HERE, go to this Portuguese site of ZTE AND DOWLOAD ANDROID USB DRIVER OF Z721, INSTALL THE SAME TO COMPUTER, REMOVE ALL OTHER USB DRIVERS FROM PC, DOWNLOAD BRAZIL ONE KEY UPDATE TOOL, INSTALL TO PC, NOW OPEN YOUR ZTE, OR KARBONN A1 REMOVE BATTERY. AFTER OPENING ONE KEY UPDATE TOOL JOIN
PC TO MOB. JUST CLICK ON DETECTION AND WAIT TILL END. sitehttp://www.ztebrasil.com.br/products/mobile/detail/Portugal/Portugal_mobile/detail/201202/t20120218_284707.html
hey guys!
I would stop what you are doing and just use the phone as is. You really need to ask yourself if rooting your phone is worth the hassle of the possibility of it bricking. If you brick your phone will your parents be upset? Are you ok with not having a phone then? This forum has hundreds of examples of people rooting there phone, messing it up, then have no idea what to do with the expensive paper weight in front of them.
In addition, I would be more encouraging to you if you had a well supported phone such as a SGS2 or a Nexus etc... which have tons of information out there regarding rooting/flashing etc.... A phone with little support and someone who isn't much of a techno is a bad mix. Think about it before you go any further.
