Help Help me read my battery chart
Unplugged from charger at just under 90%
throughout the day you hit some areas with no network reception (red bars), the majority of the time it was medium to low (yellow), with occasional great reception (green)
You restarted the phone twice (two black vertical lines).
Battery really took a nose dive when the screen was on in the last 1/4 of the graph.
as far as the awake problem, i cant comment on that since i dont know. Mine's sitting at 10hrs with 64% left (ext. battery). I read someone posted that it has to do with the camera and google+. Try turning on the camera and closing it after you unplug it.
Thanks! You mean turn on the camera while charging unplug the phone then turn it off? What is that supposed to do?
one of the mods said something about the camera and google+ keeping the phone from idling and therefore using up the battery.
When you unplug it, simply open and close the camera application.
