Help help me to bypass the google activation
Hi everyone .
I have a T-mobile mytouch 3g without the HEADPHONE JACK at the top
After i tried to root my phone I get stock with the
tap the four corners of the black area around the little green dude.
top left --> top right --> bottom right --> bottom left
You should then be able to set up a wifi connection and be good to go
hi pupkact
is this trick of clicking in the corners will make me able to activate wifi connection or what ?? :confused: , and if it does is there gonna be any indicator that wifi connection is etablished
hi pupkact
Yes, go into settings and turn on wifi. You should then be able to configure it for your connection just as you always have. From there, you can sign into your gmail account and the device should work just like a normal phone, it just won't have a cellular data connection and no phone calls. Normally there is a wifi indicator next to the clock, but this can vary depending on the skin / launcher.
but this is the probleme I can't go to setting i have just apn settings i guess this is an old version of android
