More simple actually then what I said. Guess I'm stuck on that because before superoneclick I was skipping a few steps if it didn't work. As for JIT, if you can't install it, don't worry. I never felt the difference with or without. Actually I think it was a bit laggy with JIT. Now I don't even use it. I really don't need the extra processing power.Or that!More simple actually then what I said. Guess I'm stuck on that because before superoneclick I was skipping a few steps if it didn't work. As for JIT, if you can't install it, don't worry. I never felt the difference with or without. Actually I think it was a bit laggy with JIT. Now I don't even use it. I really don't need the extra processing power.
hey guys does any one know how to fix my x8 it stuck in se logo and my xrecory doesnt work either.. how can i solve it need help plzzz huhu...
Hi,
1. switch off Xperia x8
2. launch PC Companion
3. go to software section of PC Companion
4. hold back button of Xperia x8 connect usb to PC
5. PC companion should detect X8 phone in recovery mode and start to download and reinstall software.
cheers
gabe
PC Companion is rescuer ^^
I have this exactly same problem (phone stuck at sony logo) but every time I try to solve it using either PC companion or Update Service... the program tells me i already have the latest software and that it can't download anything... what can I do???
Metro Full Flash Guide For the Sony Xperia NO NEED TO ROOT TO FULL FLASHDoes anyone could help me to flash my x8??
I've enabled JIT but after rebooting, my phone can't start, just stuck on Sony Ericcson logo, then reboot again, please help me..
