Help HELP ME TO UNLOCKING MY ANDROID BOOTLOADER
Hafiy123
i use asus zenpad c p01y and i use latest minimal adb and fastboot.When i tried to unlocking my bootloader ,the result is FAILED (remote: Can not get partition size) please please please help me everyone!!!
Yes,my device is support bootloader unlocking.I use fastboot flashing unlock but its not working.I already use fastboot flashing unlock_crtitical ,fastboot flashing get_unlock_ability and fastboot flashing unlock_bootloader (my request) and all of them is not working and show me FAILED Can not get partition size.
Firstly, is your device on USB debugging mode, as seen in the developer settings?
Secondly, did you make sure to reboot into recovery mode first using the "adb reboot recovery" command in Minimal ADB and Fastboot?
I am very sure i ìn USB debugging mode and i use fastboot not recovery right. adb reboot fastboot and adb reboot bootloader that i use it.
Not familiar with your device but on some new phones and tablets, you have to enable OEM Unlocking in Developer Options before you can fastboot unlock.
Not sure what to tell you, @Hafiy123, your's is not a device I'm familiar with...sorry :(.
You could try posting in the XDA thread I listed above...that sounds like it's probably your best bet at this point.
Best of luck!
Oh i forgot.my bootloader will be unlocked if there is no error because it says unlocking bootloader...... and failed can not get partition size.and 1 thing there is a lot of question about asus p01y at XDA to root and unlock bootloader and there is no answer.
