Welcome to the Android Forums!
Unfortunately there is only one way known to get past a screen pattern lock. After unsuccessfully repeatedly attempting to re-create the screen pattern, Android will "typically" prompt you for your Gmail username/password. This is Android's screen lock bypass. If you don't know (or have forgotten) your Gmail credentials, sad to say, doing a factory data reset on the phone becomes the most viable option.
