Root Help me!!
So I unlocked my phone and flashed mobster_Rom and gaaps and when i rebooted my phone it stayed on the HTC screen for over 15 minutes so I took out the battery and turned it back on in recovery, but it wasn't fastboot usb, just fastboot. so i took out the battery again and tried getting it back into recovery with the usb plugged in, but now I'm stuck on the HTC screen again:( what do I do?!
You don't need to flash gapps with Mobz rom. Just follow the directions like he posted. I think you only need to flash gapps on aosp roms. Anyway, take out your battery for like 30 seconds, put it back in, press and hold power and volume down. That should bring you into fastboot. Choose recovery (on the assumption that you installed a custom recovery). Restore your nandroid (on the assumption that you made one before attempting to flash a new rom).
When it's stuck at the HTC white screen don't power down, just plug it into the computer and use adb to reboot.. it's suck in a boot loop.
Code:
adb reboot bootloader
