help , memory card , what have i done
snox187
ok , so i have got new memory card and transfered of old card to new card along with load of new tunes , the phone does not find memory card and when i tried loading memory card to laptop again it is not doing anything , am confused , any ideas as it drivin me mad , phone saying sd card missing
You will need to format the SD card on your phone.
It will wipe off all the data that was on there so back it up to your PC if you have to.
Go into settings.
SD card & phone storage.
It may highlight Unmount SD card if so press that.
Below that you will see.
Format SD Card. do that.
Hopefully that will cure your problems.
