Help HELP! Music player won't stop randomly coming on!
starmint
My Samsung Galaxy Relay was recently updated to the new Jelly Bean OS however it didn't fix my random music problem. I know a lot of people have a problem with the phone playing music after inserting headphones however my problem doesn't seem connected to that. I mean I have been plugging it into an Aux cable but I don't see any connection to the problem with that.
The stock music player will randomly start playing music, sometimes when I unlock the phone, get a text message, reboot, or maybe not even touch it, it will just start playing music randomly!
My phone isn't rooted and I cannot disable the app. There is no particular playlist playing and exiting out of the app or "task killing" it doesn't fix the problem either.
Any suggestions? It's hard to troubleshoot too because it's sooooo random.
It sounds like you have voice command activated. Updates to some apps seem to turn it on. Go to Home screen. Select Language and Input. Scroll down to and select Voice cmd for apps. Scroll down to Music. Make sure it is NOT checked. Exit out and you should be ok. Let us know if that fixes your problem. You may need to reboot your phone to make it stick.
In my settings I see the Language and Input option however under that I don't see Voice cmd for apps Is there any other location this setting might be under?
Thank you.
Ok I found it under S Voice settings however Voice Control is off and I see the music option is grayed out. I unchecked it just to make sure but voice control is set to off so that probably isn't it. Will post if anything different happens. . .
