Help help! my clicks arent working!! :(
daniel178
Member
! Screen Lock & Audible Selection sounds not working!
Hello,
So I don't know exactly when it started happening, but my "audible selection" (makes sounds/clicks when you press soft buttons on screen) and my "screen lock" (makes sounds/ clicks when the lock-unlock slider is swept) are no longer working.... Or, they are EXTREMELY quiet (can't hardly hear them, even in a silent room). No new apps, etc. Running BAMF 1.3. (but I did still have the sounds for a little while after flashing the ROM). any ideas?
I don't want to use an app.... I downloaded Audio Manager from the market and my clicks were soft and then loud and then non-existent.
Hello,
Have you tried pulling the battery?
That is probably another thing they gonna correct with the upcoming update. It was happening with my first TB, and it is happening now as well with my second one. I swapped phones yesterday.
Yeah, I am now on my 2nd thunderbolt, and this one is doing it too, right out of the box.
"That is probably another thing they gonna correct with the upcoming update."
What, if ANYTHING, makes you think this is gonna happen? I highly doubt it...
mine does the same thing. the first tap of anything theres no click sound, but theres a click sound the second time i press something. it really pisses me off
To check if the volume is low, download Quick Settings and make sure that the "System Volume" is all the way up.
I WAS FACING THE SAME PROBLEM FOR ONE WEEK. I HAD THIS ANDROID ASSISTANT INSTALLED. I WENT IN IT TO CLEAN UP CACHE.
THEN I SAW THE OPTION TOOLS IN IT. THESE IS ONE MENU BY THE NAME OF SOUND.
IN SOUND YOU WILL FIND SYSTEM SOUND WHICH WAS 0% IN MY CELL. AFTER MAKING IT TO 100% ALL SOUNDS WERE BACK .
SO JUST GO AND INSTALL THIS ANDROID ASSISTANT LINK IS AS FOLLOWS
https://market.android.com/details?...wxLDEsImNvbS5hZHZhbmNlZHByb2Nlc3NtYW5hZ2VyIl0.
AFTER INSTALL OPEN ANDROID ASSISTANT --> TOOLS --> SOUNDS --> SYSTEM SOUND --> SLIDE THE SLIDER TO 100%.
