To mount the Epic 4G as a drive and enable Mass Storage mode, ensure USB debugging is disabled as follows:
Disable USB debugging mode:
1. From the home screen, press the Menu key and tap Settings
2. Tap Applications.
3. Tap Development.
4. Ensure USB debugging is not checked.
5. Press the Home key.
6. Connect the USB cable.
7. Tap Mass Storage and the Epic 4G will display as an available drive.
Pull down the Notification Menu and tap the "USB Connected - Select to copy files to/from your computer." Tap "Connect storage to PC."
When you are ready to disconnect from your computer, tap the "Disconnect storage from PC" button. If you don't see it, pull down the Notification Menu and select "Turn off USB storage."
3. Tap Development.
