Yes my Husband dropped my d3 into our dog's water bowl and he did not tell me. He just plugged it right back into the charger. I not knowing went to use it a little bit later and was having some trouble. I tried to turn it on and off and got almost nothing. I then thought some times if I remove and replace the battery it would be fine. Well when I removed the cover and the back face plate there was my problem...WATER
. I asked my husband about the water and he said yes he did. He did not think it would be a problem so he wiped it off and put it back on the counter. At that point we looked on line and saw the rice thing....only we had already done eveyrthing that you are not supposed to do. Well this was Sunday and it is now Tuesday and alas I have not had any success.
Because I only got this phone last summer I am not due for an upgrade from Verizom until March 2013. I just don't have an extra $500.00 for a new Droid 3 right now. Does anyone know if it is possible to purchase an ulocked Droid 2 and put it on my to replace my Droid 3 until I would be allowed my 2 year upgrade? I have found a couple of the unlocked d2s on ebay and amazon. Thanks in advance for you advice.
