Help HELP! My tablet isnt updating to ics...
speedygonzo
Member
Ok so my TP was just rooted and i ran OTA Rootkeeper to save root.
So i accepted the update and it was about half way finished when i saw the green android with a yellow triangle with a black explanation point on it...
So any way, it rebooted and tried it again. Same thing happend...
So i factory reset the tablet and tried it once more. Same thing... tried one last time and it didnt work... same thing...
Please help me update my tablet.
Thanks in advance
Im gonna guess you froze or deleted some bloatware?
The OTA will not take unless you have all the stock apps installed. So hopefully you can put them back into system>app and all should be well.
I rooted last night, and took the OTA tonight. Used OTA Rootkeeper, and am rooted on ICS.
Correct, I only removed one system app and that was the "@vibe music" app.
I did back it up using TB and when I try to restore it it takes forever and will not restore.
Any suggestions?
Ill pm you the apk, you should be able to move it to system>app and install.
Gimmie a few min and ill shoot over a link to you.
