Root help! nbh files?
Use the unlockr website. I recently rooted using that website. Here are the step wise links that you might need:
Step1
Step2
Step3
Before loading any rom, find out from xda what all other files are required for your phone. Download all the files and double check before you start rooting.
Note: I am using superD, but it seems to be having a problem with the mic. There is a fix out there, but unless you are prepared to do some adb coding, stay away from it. Though it is not very difficult (and this is the whole point of rooting)
