Root HELP! need a stock recovery!
Every1BHS
My samsung admire is bricked, can't start up, And ALSO cant charge it (I get a little yello triangle when I try to.
I have CWM 5.0.2.7, And I need a restore that I can restore to stock, 2.3.4, or 2.3.6 I dont care I just want it to work! Help?
Can you get into cwm? If so, then download any 5.0.2.7 rom and flash it. If cwm doesn't work, then does Odin work? Take your battery out, put it back in, and press the camera button then plug in it to a computer. You'll see a yellow triangle. Press volume up. If Odin works, then run the 2.3.6 update tool.
I can get into CWM, But for some reason I keep flashing Stock 2.3.4's and 2.3.6's and when I start my phone it freezes on the SCH R720 screen OR the Samsung Screen. Any ideas?
AND, are there even any 5.0.2.7 roms? I cant find one, Please help!
EDIT: I just tried to flash The Monster 4 ROM and on boot it froze on the SCH R720 screen, Please someone help..
If it's stuck on the samsung screen or sch screen than it sounds like you have a softbrick probably from a messes up flashing or something.
Have you tried to go in download mode? That would be the easiest way if you can. Also there are a lot of 5.0.2.7 roms. If you didn't find any you must not have searched long enough. Here are the top 3
http://androidforums.com/admire-all-things-root/554987-rom-admired-monster-5-3-now-stock-kernel-build-phones-dont-take-oc-kernel-well.html#post4433299 The non-ext4 build is a 5.0.2.7 rom.
http://androidforums.com/vitality-all-things-root/614099-rom-oa-2-3-20-no-oc-rfs-final-lazy-cpu-userbase-updated-09-08-12-a.html This is another.
http://androidforums.com/admire-all-things-root/649161-updated-11-23-12-rom-android-world-order-overclocked-2-3-6-a.html This rom has a stock version included in the installer.
That isn't all of them but those are the most used I would like to think.
