Root help need to access phone memory
ok iv'e tryed changing my lock screen font on the clock, and my phone rebooted and all it does it keeps restarting over and over and....... you know, all i need to do is to access my phone memory via computer, its flashed to boost and rooted ( paid for ) i have the original font on my mms please help:confused:
Tried you to simulate a battery pull (holding down the Power button for more than 10 secs) ?
Then restart and trying to get the Save Mode (holding down the Volume down button while the HTC logo is on screen).
Harry
Harry
im trying and i cant, remember its rooted and flashed to boost, all it does when i leave it alone when it starts up it gives me the HTC EVO 4G logo, then then the Sprint logo then 4G logo and it stands like that for a few seconds and it goes back again sprint logo 4G logo again and again, when i try to go into save mode it takes me to root menu
Don't know a lot about boost but, can you boot into recovery?
if you mean hboot menu while holding power + vol - yes, all i want to do is access the main internal memory on the phone like data,system and such folders with my computer to fix and replace the file i changed, or even by phone
Can you access recovery from the bootloader (hboot) screen?
If you can, go into recovery (I dont know what, if any, recovery you have).
Do you even have a custom recovery?
o.k....like I said, I don't know much about boost but when in recovery, maybe wipe cache and dalvik cache and reboot....try that....hopefully this thread will get moved to the "all things root" section and other people there will help:)
ok did it and nothing yet, all i want to do is access the internal memory and change some files,remember it's rooted and flashed to boost and wifi tethered and i payed for it, i dont want to hard reset cause it will not work for boost any more right?
Once you're in recovery, you should be able to mount /system and use adb to push whatever files you need to replace.
and how to i do this " use adb to push whatever files you need to replace"
unfortunately I don't have time right now to give you a tutorial on adb, but a Google search should yield some good results (I think there are quite a few out there). If not, hopefully a guide can step in and link you to some that can help you in your quest.
What I can tell you is the main command you're going to end up needing is "adb push".
