The adb commands are
adb remount
adb push "whatever the amazon.apk name is" /system/app
adb reboot
Make sure the apk is in your tools folder
Or you can just save it to your sd card and move it to system/app using File explorer
Tried using Linda File Manager and got denied.
As for the other commands, can I do this through terminal emulator or do I need adb? What exactly does remount do anyway? And will push MOVE the file or copy it?
Thanks for your help!
Yea, you can do it thru terminal emulator
commands are ...
su
mount -o remount,rw -t yaffs2 /dev/block/mtdblock4 /system
cd /system/app
mv amazon.apk amazon.bak
cat /sdcard/amazon.apk > /system/app/amazon.apk
sync
mount -o remount,r -t yaffs2 /dev/block/mtdblock3 /system
adb remount is just a quicker way to get read/write access, instead of doing the "mount -o remount" mumbo jumbo
Also you need root explorer or any other file explorer that has su permission.
I wonder if i wiped my wifes old mytouch and then saved a backup file if i could then email it to you as an attachment and you could load that backup on your phone? I dont see why that wouldnt work...
sent you a pm phateless, this should do the trick.
Thank you! Just replied, will report back.
Cool, let us know if it works.![]()
