Help needed-Apn wont turn on!
CarsnGadgets
Android Expert
Last night I put the phone in airplane mode over night.
Apns were turned off when I did this. (I do this every night to save battery).
This morning, I turned airplane mode off, and tried turning Apn on again, but it wont turn on. (I use Extended Controls Bar widget)
I have done a soft reboot (3 actually), but that made no difference.
If i go to menu/settings/wifi and network, and look at the text next to the mobile network (Apn) checkbox it says: Connection failed due to incorrect APN setting.
I havent changed any settings as far as i know.
anyone have any ideas how to get it working again?
It just turned on ok...
odd, as i have tried about 20 times since i got up with no luck.
Maybe it was an O2 problem, not my phone?
I had this problem and I think it was Juice Defender. I think it's related to a bug in the Desire/Nexus One firmware. I wouldn't advise using it.
In the end I had to go to the Network settings and restore the default APNs
Go into APNs
Press Menu
Reset to Default
