Root Help Needed ASAP
jmckins
Member
I just rooted my phone and went through all steps and everything worked. The problem I am having is getting my phone back to normal mode. The last step of the root was to reboot the system which I did but it always brings me back to CwM Voodoo Lagfix Recovery v2.5.1.x mode. Please help!
Thanks
Jared
Thanks
Jared
I don't know what steps you took, or what you're doing specifically, but I would try reinstalling whatever update.zip or Rom you tried and see if that works. You might also download it again to make sure its not broken. Sometimes just reinstalling actually works.
There's is a helpful XDA thread that might be useful here.
