Help Help needed for broken screen! Phone partially survived.
r011z
3
0
Hi guys,
Really hope someone can help because my situation is quite tricky! Basically my HTC Desire Z got run over and the screen is cracked but the keyboard and sounds are still functioning.
I really want to get my contacts back so I was wondering if someone can provide keyboard shortcuts to exporting my contacts onto memory card. Eg. 1) press menu 2) scroll up 3) press enter
I'm basically running blind so not sure if this will work.
Another alternative is to use HTC Sync via USB. However, I believe it is defaulted to CHARGE only when I connect the cable but need a way to change it to sync storage using keyboard shortcuts.
Hopefully someone can help, will be very much appreciated :)
Cheers
Rolly
Hi guys,
Cheers
Rolly
Upvote 0
BEST TECH IN 2023
Smartphones
