Help help needed link2sd
kitwalker
Member
i wish to create a 1gb partition in my sdcard and use it
plz help me how do that..
is there any risk with link2sd
which are the apps safe to move to sd card
Boot into CWM and there is option to create SD-EXT partition.
Create SD-EXT Size 1GB and swap 32 and reboot...Then install Link2SD from market, after install it will prompt you to select partition type.. select EXT3...
After that go to link2sd settings-select AUTO LINK-select install location as automatic.
From now on all the programs u install will link to your SD-EXT partition.
Plz don't remove any system apps which are in system(Click menu in Link2sd-select filter-select system)
HIT THE THANKS BUTTON, IT WILL COST NOTHING. TRY IT..
To partition sd card go in advanced in recovery and select partition sd card.
Then choose 1024mb from that and select swap 32 and partition it.
There is no risk in using link2sd but don't link system apps in that.
am using stock rom(original one)
and i wish to make partion with linux gparted app
so i wish to know how do that..
i have read first partition should be fat32
i want to know the second one..
its it ext2/ext3/ext4??
the link2sd ppl say only two partitions
thanks for the replies
one more doubt i have alldata and apps in sd card if i resize and put back all the original things will it affect my previous apps will they work
or i need to uninstall apps and then again install them??
my phone is rooted
should i unroot phone and do this partition or
it has no role to rooting
i wish to move google maps and yahoo messenger along with its plugin to new
partition is it possible
my phone is rooted
Your phone has to be rooted to use this app.
You can move yahoo messenger but don't move Google maps from internal memory.
my phone is rooted already i told in reply too friend
i just wish to know what kind i should give to the second partition
ok thanks for the info on google maps
Make it a ext 3 and it should 512mb its enough as you don't have enough ram 1gb won't be good...through titanium take backup of maps and uninstall maps..when you want them just install again ..with data plus app..
