tripledigit
Help needed please from a newbie !
My Desire got wet,I immediately took it apart,left it in front of a heat gun gently warming it dry,i put it back together and it worked perfectly, (made calls,sent messages etc,it remembered all settings except date)I then picked it up later to find it dead,i have tried to switch it on and tried a few other techniques like holding down the Power and Home button etc to no avail,it did however turn on sometimes and the screen gave some options of Reboot/Bootloader etc in small writing,I guess a lot of you are familiar with the reflash etc I could switch between options using the Volume buttom but couldn't select anything,then sometimes it did but it then went dead again and nothing,any ideas please? Is it now junk or can HTC fix them when the water damage tab goes red?go easy I'm pretty new to this!
(sorry if there's a better place to post this)
, isopropyl or "rubbing" alcohol) to the device, which will displace what moisture may remain. The alcohol will evaporate and not harm the electronics or the screen, etc, as long as it is pure alcohol and not scented or some sort of mixture (witch hazel, aloe, etc).
