Root Help Needed Please
db1980
Hi Guys I decided to free my Desire HD and go for some custom roms that I have read so greatly about ..... BUT something went wrong..
Details as follows
Not rooted and s-on
ran a programme called The Advanced Ace Hack Kit
file : aahk-13012012.zip from forum .xda-developers .com showthread.php?t= 1259821
all worked fine or seemed to until reboot, then when you turn on it just hangs on the t-mobile screen.
when I run recovery it says E:Can't open /cache/recovery/command
have tried wipe data / factory reset always the same result
screen reads
ACE PVT SHIP S-ON RL
HBOOT-0.85.0024
MICROP-0438
RADIO-26.03.02.26_M
eMMC-boot
apr 12 2011,00:55:45
hboot usb and fastboot usb when plugged in
FASTBOOT
RECOVERY
FACTORY RESET
SIMLOCK
IMAGE CRC
would be very grateful for any suggestions on how to fix my mess...
Thanks in advance..
I'm not sure if this is wat you should do (it's wat I'd try!!)
Download a custom rom onto your sd card
Boot into recovery/install zip.
Someone else with far more knowledge can help better than I can.
Pep
Do you know what your software version was before the attempt at root?
I suspect you'll need to get your phone back to a workable state with an RUU, then run the hack kit again.
