I got an Evo and It had a custom rom with unvrevoked3 the problem is that the camera wasn't working, I downloaded myns warm 2.2, put it on the sd card named update.zip and installed it on the evo using the volume down button and power to apply the update.zip after wiping the data and cache.
When it finished rebooted the phone now it doesn't move from the HTCEVO white screen at the begining.
I'm new at this. Any help????
) but I think if you rename the file it messes up the signature. Again I could be wrong, not sure though. Anyways I would try and re download the rom and keep it as is, then wipe data, cache and dalvik, then select install zip from sd card. That should get you squared away!
