Root Help needed
woowoo11
Ok so I woke up this morning and all my pictures are gone from the gallery. :eek:How do I access the SD card to get the pictures from there? Or are they even there?
connect to computer and drag done the notification bar and tap USB Connected and than tap Mass storage.
Is this the same info for an Huawei Ascend? Plus everytime I hit USB connected it just prompts me to "mount" over and over
was it save to the sd card or the internal memory, you might need to turnof phoneand removed the sd card than reinsert it.
I'm not sure, all I know is there were about 20+ pix in the gallery and now they are gone, just trying to recover them.
do you have a card reader if so put it in the computer and open the DCIM folder and see if your pics are stored in there.
