Help !!!! No 3G
Batbriel
I dont know if there is something wrong with the network or if its just my phone. I'm Rooted, currently running White Widow 4.4 and the 3G icon is not showing up on the status bar and I cant access , the market or facebook, nothing !! any ideas, suggestions ?
Are you using the device under the same conditions and in the same place(s) as when it was showing 3G?
Yes already tried *22899 and yes I've been using the device under the same conditions and in the same places as when it was showing 3G and my wife has the same phone, she isnt Rooted and she shows 3G and no problems
I feel kinda stupid even asking this... because I"m sure you did this. But i gotta ask anyway...
Are you sure Mobile Networking is on?
Hold down power-
Mobile Network should be ON
Ok it is Fixed !!! not sure if got something to do with but before I lost my 3G, I updated an app from the market, SwitchPro Widget to be more specific, so I uninstall it, rebooted my phone and now its back to normal
Ohh.. well, that app is connection sensitive.
Good to see you're good to go now.
I lost 3G for a few hours today. Might have been something up with the network
Didn't bother me though, since I was out fishing and just wanted to check in on FourSquare
