followed these instructions to update my LG optimus black p970 to ics (the flash using smartflash tool)
http://www.hackmyandroid.com/optimus...cs-update/3299
seemed to go fine and update to ics the only error (which happens to be major) is that now i get no service error for every sim card no matter the network (the phone is unlocked).
the imei & baseband are now unknown (i read this might be the cause of the problem?)
ps i'm a noob. i did read a lot before doing this but most of what i read said it was a foolproof method....
what can i do to fix it.
(i'm guessing someone will say "flash (not sure if thats the correct term) it back to 2.2 or 2.3 (it was on 2.2)" the thing is i dont know how to do any of this.
would appreciate help and intructions :]
*although ideally i could keep it on ICS and have it working.....
