Help Help Notification Bar issues?
Hi Guys newbe here, looking for some help please i have the galaxy s2 on orange and when i receive notification as in emails and messages they only stay on the notification bar for a short period? even when i do not touch the phone the or read them they disappear? any help please?
Thank you
Scotie
Just pull down the notification bar.... Its still there. Press the notification bar near the top and swype down. You definitely don't want the notifications to keep scrolling keeping both the screen and phone awake. Sucks your juice flat.
thank you for the reply, no they really are knowhere to be seen mate? i see them in the bar when they arrive dont touch the phone they are not there when i check after 10minutes?
scotie
You may have to go to the settings in either your emails or texts or whatever. Then check off email notifications. You'll always get a quick notification, but when you check this off, it should always be there until you check them.
Hope this works.
Hope this works.
Hi thank you guys for the help i have fixed this problem its a power setting issue? when i have it on normal power they stay in the notification area when on reduced power like i said above they don't stay for long?
scotie
