hi all.
i have a black htc desire unlocked.
the wifi works fine.
just added the web data bolt on but i cannot connect.
i ring up o2 who sent me details on how to manually type the settings in:
now it still does not work!!
please help me!!
i know its not my sim as i used to have the bolt on before and it worked fine on the htc hd2.
- Press the Menu key
- Tap Settings
- Tap Wireless & networks
- Tap Mobile networks
- Tap Access Point Names
- Tap New APN
- Tap Name then tap the text box and enter O2 Pay Monthly MMS then tap OK
- Tap APN thentap the text box and enter wap.o2.co.uk then tap OK
- Tap Proxy then tap the text box and enter 193.113.200.195 then tap OK
- Tap Port then tap the text box and enter 8080 then tap OK
- Tap Username then tap the text box and enter o2wap then tap OK
- Tap Password then tap the text box and enter password then tap OK
- Skip past Server as this is preset as Not set
- Tap MMSC then tap the text box and enter http://mmsc.mms.o2.co.uk:8002 then tap OK
- Tap MMS proxy then tap the text box and enter 193.113.200.195 then tap OK
- Tap MMS port then tap the text box and enter 8080 then tap OK
- Tap MCC then tap the text box and enter 234 then tap OK
- Tap MNC then tap the text box and enter 10 then tap OK
- Tap Save
- Tap your new account so a green dot appears next to it
- Press the Back key four times to return to the standby screen.
please help me!!
