Root Help on Downgrade DHD from Gingerbread
any help please!!!
adb push misc_version /data/local/tmp
adb push GingerBreak /data/local/tmp
adb shell chmod 777 /data/local/tmp/misc_version
adb shell chmod 777 /data/local/tmp/GingerBreak
adb shell
I keep getting the $ sign after typing adb shell. and when I continue with the code it by entering
./data/local/tmp/GingerBreakI get; cannot copy boomsh : permission denied
any help, at all?
It is supposed to be downgradable. so surely there is a way.
I've tried to use a tool called ATM
Advanced Multi Tools.
This has supposedly rooted my GingerBread, but when I go into bootload to start the update it just do anything.
Any help is greatly appreciated.
Thanks
Do you have a link to Advanced Multi Tools? Gingerbread isn't rootable unless you have S-OFF and if you haven't downgraded, I'm 99% sure you won't have that.
How did you factory reset? Via the settings app or via the bootloader?
I can't really say it is actually been rooted, although the App does say it. when the app connects to DHD and is asked to root/downgrade the phone a msg comes up on the screen of the phone asking to grant superuser privileges, which I allow it. now this was never achieved through CMD method above, I never got that msg.
Well my phone is unbranded, but I'm not sure if S-OFF as I bought it 2nd hand.
The factory reset was done by Bootloader.
Here is the link for ATM
[TOOL] [11/07/11] AMT v1.8.1 - Sim Unlock, S-OFF, Downgrade - Added Auto Detection! - xda-developers
Go into the bootloader again, does it say S-OFF in the first line?
Like this:
And you already have the Super User app on your phone? If that's the case, and you have S-OFF, you're probably already rooted. Try installing an app like Titanium Backup, if that's allowed to run, you're definitely rooted.
You should then be able to install ROM Manager, then clockwork and start flashing custom ROMs.
Like this:
Unfortunately, Titanium Backup says Root Access has failed.
Any ideas?
The factory reset normally solves it.
You could try factory resetting, then not linking the handset to your gmail account so it doesn't start installing apps again? That way the handset is still "clean"?
I've not tried this as It turned out S-ON as indicated in BootLoader.
- Back to square one, I guess.
Can anyone advice on what could've gone wrong in the cmd approach?.
Well, what I did is
1- Re-created Goldcard after factory reset
2- then I typed
adb shell
which gave $
and then i exited and tried this
adb shell /data/local/tmp/GingerBreak
which gave this
[**] Gingerbreak/Honeybomb -- android 2.[2,3], 3.0 softbreak
[**] (C) 2010-2011 The Android Exploid Crew. All rights reserved.
[**] Kudos to jenzi, the #brownpants-party, the Open Source folks,
[**] Zynamics for ARM skills and Onkel Budi
[**] donate to 7-4-3-C@web.de if you like
[**] Exploit may take a while!
[+] Plain Gingerbread mode!
[+] Found system: 0xafd17fd5 strcmp: 0xafd38065
[+] Found PT_DYNAMIC of size 232 (29 entries)
[+] Found GOT: 0x00014360
[+] Using device /devices/platform/goldfish_mmc.0
[*] vold: 1232 GOT start: 0x00014360 GOT end: 0x000143a0
[*] vold: 1232 idx: -3072 fault addr: 0x000132b4
[+] fault address in range (0x000132b4,idx=-3072)
[+] Calculated idx: -2005
[*] vold: 9234 idx: -0002005
[*] vold: 9234 idx: -0002004
[*] vold: 9234 idx: -0002003
[*] vold: 9234 idx: -0002002
[*] vold: 9234 idx: -0002001
[-] sendmsg() failed?
[*] vold: 9299 idx: -0002000
[*] vold: 9299 idx: -0001999
[*] vold: 9299 idx: -0001998
[*] vold: 9299 idx: -0001997
[*] vold: 9299 idx: -0001996
[!] dance forever my only one
now the cmd froze after this and didn't allow me to input the other two lines.
I restarted into bootloader, but no update requested was initiated
I can't get the same msg if I redo cmd commands, would get somethig like boomsh permission denied.
I have to factory reset and redo all steps to get the same result.
any advice please?
Thanks
I've done the steps again, and this is what I got
However, when I restarted into Bootloader, there was no update launched.
Because it's not that kind of temp root. It's only via the command line and only really works for the purposes of forcing the phone to accept the downgrade file.
Did you get put in the last command, mess about, then boot into bootloader or did you reboot straight away?
Also, if the PD98IMG.zip was on the SD Card, did it download correctly, do you know how to check the MD5 checksum of it to confirm?
Did you get put in the last command, mess about, then boot into bootloader or did you reboot straight away? ?
I've done twice now, one messed about, the 2nd right away, they both gave me the same thing, same old bootloader screen.
I've just done it and it gave this D5067EAAD6D447797A67828B567901AF
Does it look right?
I had to do everything again to make sure I don't miss out on anything, but I get the same screen with Fastboot,Recovery, Factory Rest, SimLock, Image CRC.
Any thoughts?
