Root help on overclocking 2.2.1
You need to flash the anyrom kernel http://androidforums.com/optimus-m-all-things-root/347684-kernel-optimusm-oc-stock-2-2-1-a.html
The download is in the link thread, also 2 things. One, to overclock I have found setcpu to be the best app, you can get it free if you sign up at xda. I would recommend supporting the devs and donate anyways though. And the second thing is joneidys sense rom comes with the kernel already. It's a very good rom i've had no issues at all so you could just flash that instead of the kernel. Either way, good luck and I hope I helped.
oh thanks thats what i was looking for but .
as for the recovery , i ran into the same problem, 2.2.1 , i couldnt find a recovery for it ..
again any help would be usefull
