Help help opening up my desire hd...
rhod
was hoping for a bit of help... the bottom left of my screen has come away from the phone slightly. I can push it back and it stick for about half a second then back to normal. not sticking out a lot but enough for dust and bits to get under the screen. I therefore want to open up the phone and see if i can fix it and clean away the gathered dust underneath.
has anyone done this before? if so i'd really appreciate some advice on how i go about it.i have insurance if it all goes t*ts up!
cheers
