Help Help-Organising Contacts Google-Facebook
Enyalios
Hello, im a new owner of the X8. I ve been desperately trying to put my contacts in order with very little success so far. After an extensive Google - forum search i didnt find a complete and comprehensive guide of how to properly categorise all the people I know, and this is my final resort!
My ultimate goal is to organise my contacts once and for all, to try and connect all accounts together, to eliminate duplicate entries, to get everything working
So here is the story so far :
Old phone was a Nokia and bought new X8 with android 1.6
In order to transfer contacts from old phone to new (number was larger than SIM card capacity), I imported contacts to outlook, exported them to a csv file, uploaded to Google Contacts.
Issue No 1: I can only assume that i created some duplicates during that step, since i didnt erase contacts from sim card. I found no way to isolate SIM card contacts on X8. I suppose Phone Contacts refer to internal memory stored entries and not specifically SIM card.
From then on, i decided to try and link all this to Facebook, therefore after a quick search I used SyncMyPix, which performed beautifuly.
Then I found out that Android 2.1 was available for my device and decided to upgrade using the Update Service.
When the update was complete, I synced my X8 to Google Contacts again and i found out that automaticaly my X8 matched Facebook contacts with Phone Contacts presumably according to names. I found no obvious way to manually connect Facebook Contacts with Phone Contacts where names did not match. I did not try update all my contacts with their E-mails manually since i have too many of them and not everyone keeps their Email public in Facebook. I signed up with Sony erricsson Sync, which did not have a solution to offer since I didnt find a Contact Management Interface anywhere.
Therefore ISSUE No2: How do I manually connect Facebook Contacts to Phone Contacts ? When i select a contact and press Edit, there is no such option. If I press the Timescape infinity button, Again no such option.
Question - Issue No3: When I select a contact and then press Edit, there are usually 2 different sections underneath. One reads Phone Contact and the Other reads Google. The information is usually similar or in cases one contains home number and the other mobile number.What is the difference between them? Does that mean that if i update the phone version, this will not be synced with Google Contacts? What is the ideal Setup, where every change i make on my phone is reflected in the Google Contacts automatically?
Sorry for the Wall of text, hope someone will help out, and others will be helped in turn.
try contact analyzer from market
Well I just downloaded the App and used it. It doesnt really address all the issues, and you cannot use it to merge Facebook contacts with Phone contacts. The reason is apparently because you can only select objects for merge which are under the contact name (for example a phone number, address etc) whereas the Facebook contacts are blank and do not contain any mergable objects beneath them. Thanks for your help though :)
oh my bad...
Ok so I am still a little muzzy headed so bare with me here... (just getting over flu)
To join facebook and phone contacts go to your Contacts own page, scroll to the bottom and press edit and then press menu and it should give you the choice of join unjoin contacts.
Does this do what you need?
Rose baby,hope you get better soon! ;)
Hm,my opinion is that the whole Google Contacts/Phone Contacts etc thing is F ucked up.
I end up never being sure of what I have backed up or not which sucks so I use many apps to do this backup just to be safe...
N.
Yes, this does in fact solve the joining contacts issue and thank you so much for the reply. As far as Human Interaction and intuitive interface go, I think Sony failed here. Not only it is quite obscure -almost hidden - but it is not documented anywhere. Enough with the rage though, I still cant figure out what is saved where. For example : I create a new contact, and the menu prompts me to decide whether i want to save this in my phone, Google contacts etc. If i save it in my phone, shouldnt that update Google contacts automatically? Why do I have to make a choice? Isnt it the same exact thing?
