Help Help - OTA broke calendar sync
woodyt74
Something weird happened after the 2.2 OTA. I use google calendar on my Mac through caldav and it was working fine since I got my fascinate in Sept. After the OTA, the current month and all future months were wiped clean in my online and Mac google calendars but April and prior were untouched. However, the google calendar on my phone, I use Jorte and checked the stock calendar as well, everything is fine just like it was before the OTA but I can't get it to sync back to my Mac and online google calendars. I turned calendar sync off and back on and it shows that it is syncing but nothing happens. Any ideas on a fix? :confused:
PS: Battery drain was horrible too so I backed up w/mybackup pro and did a factory reset/wipe and restored from mybackup pro and that is when I noticed the calendar problem.
