Help Help! Persistent network/call connect problem on my indian XT1033
sujit
I happen to be facing network issues on my dual sim moto g (xt1033) almost since I bought i.e even when my device was on jellybean & now when I am on KitKat.
The issues I face are:
i. People are unable to reach my number/contact me almost 90-95% of the time. They tell me u were unreachable.
ii. Sometimes when they call, my phone rings for 3-4 times(only hearable to me) but the caller didn't hear any sound of the call getting placed/connected and phone ringing.
iii. while browsing data(both 2g/3g), network frequently drops. it doesn't show that it dropped. I get to know when the respective app shows that you have an internet connection failure (for e.g facebook)
Things I have tried to resolve but failed:
i. Flashed revolution g v3 brazilian stock rom and reflashed indian radio/baseband to overwrite it. got both sims working but "call connect" issue did not go.
ii.Swapped sims on both the slots. I use a BSNL 3g sim & an airtel 2g one. I noticed after swapping/may be restarting calls getting connected a bit sooner/proper than they did before. but a day after again same issue & it just doesn't seem to go.
Can anybody please tell what can be done to resolve this? Is this a hardware/software issue ? I get it irrespective of data switched on/off.
If everything fails I have no option but to convert my asian dual sim moto g into a european single sim xt 1032 as explained here http://forum.technofaq.org/discussio...-single-sim/p1 Since it's system version is 174.44.9, I believe it contains the network fix.
My current device stats:
Bootloader unlocked, rooted, stock indian firmware with philz cwm recovery
system version : 171.44.31.falcon_umtsds.AsiaRetail.en.03
Build number : KXB20.25-1.31
Use 2 sims with both active
Hi,
I am having the same problem.
Did you make the recovery before flashing your ROM for the first time?
The problem is with baseband version.
I have tried almost all possible methods to rectify this problem but no solution has come up till now.
If you find any solution in this regard kindly let me know. I will be very grateful for the same.
Thank you.
