guysilverrikar
i have a boost transform ultra and have been rooted since the guy s first posted the link THANKS
but device was loast and had to start over. no problem
rooted under a min
ok
everything fine a ok
then day before yesterday several apps started crashing over and over and pover you get the point this all started OUT OF NO WHERE
ummm i couldnt figure it out
tries updateing things
nope
then i couldnt even get the wifi teahter app to work
dont know why
so
nothing was working
so boost recomended a ##rtn
and things looked like it ewas okre rootinig but it says
some same apps where there now everything
it seemmed as if the root was still there
\butt guess what it wasnt
i went tio go use a appp that need rooting adn it says i dont have root i have tried and tried and tried
the rooting app says
OCR for Transform Ultra
Using zergRush
(All credit for exploit go to the creators)
One Clicks Done by
Interdpth and Shabbypenguin
* daemon not running. starting it now *
* daemon started successfully *
error: device not found
Wait for phone to reconnect...
mount: permission denied
1397 KB/s (4292 bytes in 0.003s)
chmod: permission denied
/data/local/tmp/rootsetup: permission denied
rm: permission denied
Copying files onto phone...
failed to copy 'su' to '/system/xbin/su': Read-only file system
failed to copy 'Superuser.apk' to '/system/app/Superuser.apk': Read-only file sy
stem
failed to copy 'busybox' to '/system/xbin/busybox': Read-only file system
failed to copy 'remount' to '/system/xbin/remount': Read-only file system
Setting permissions...
Unable to chmod /system/xbin/su: Read-only file system
ln: permission denied
Installing busybox...
/system/xbin/busybox: not found
Cleaning up files...
please help me
i can give my phone number and email addy to whom ever can help
thanks guy/gabbi
rooted under a min
ok
nope
dont know why
so
nothing was working
Using zergRush
One Clicks Done by
stem
please help me
thanks guy/gabbi
