Ok so I flashed over to Myn's Warm twopointthree Rom for the Evo 3D (absolutely my favorite ROM). I'm s-off with hboot (1.04 or something like that) I decided I wanted to try anthrax kernel (3.1.08 or something lol) with it, so I flashed over that kernel. Upon reboot, I was stuck on the HTC screen. No biggie, guess the kernel wasn't compatible with the ROM. So I went back into recovery, did a dalvik/cache wipe and went ahead and did another factory reset just to be safe, then reflashed the rom. Upon reboot again I was faced with only the white HTC screen. So I flashed SOS rom instead. Again, white HTC screen. Tried another rom, same screen.
Why is my phone no longer working? I don't see real reason this could have happened, I flash roms all the time and have never had an issue like this where no rom will boot.
Also I just noticed I've been getting this message when 4ext recovery starts, something like "SmartFlash is scheduled to update your partition upon next system start. Is this wanted? Do you want to remove SmartFlash?"
Any ideas?
Also, does anyone know what alternative kernels are compatible with Myn's Warm twopointthree rom? The 'alternative kernels' link in the rom's thread is dead. I'd like one that supports dual core and maybe overclocking. The rom is supposed to support dual core but I've never seen it actually do it so i don't think it actually does.
Any ideas?
