Help HELP!! Phone keeps freezing/overheating!
I've had my phone for a couple of months now, and haven't had any problems until now. All of a sudden, the screen had been off a couple of minutes, and when I pressed the home button the two touch buttons lit up while the screen remained off, and 1-2 seconds later the touch buttons turned off and the phone screen will not turn on.
I pressed the unlock button on the side, and the home button, I pressed both at the same time, and tried to soft reset, yet the phone did nothing. I let the phone sit a few minutes thinking perhaps it was lagging, but when I picked it up not only did it still not work but it was extremely hot! :confused:
The only way to get the phone to turn on is to take the battery out and power on again.
I have searched everywhere but cannot find anyone with the same problem, any ideas from anyone?? I want to get this fixed before it gets worse
I have the EXACT same problem. Very curious as to weather anyone has a solve. went to local Verizon Store. they suggested a hard reset. Problem started after the last update pushed to the phone 2 weeks ago.
To both of you, was the phone itself (area around the SD card) hot or was it only due to the battery overheating? I know these batteries can burn extremely hot if they ignite.
