AppleTechies
I was installing Revolution HD on my Droid Incredible 2. I knew that the first boot took longer than usual, so I waited it out. I even went for a 20 minute run, but the phone was still booting up when I came back!
The white HTC screen was frozen, so I got tired of waiting and pulled the battery. I was sure that I had done all the installation steps completely: run the super wipe file + install the rom. So i did a reboot and ended up waiting another 10 minutes for this thing to boot into the rom. I pulled the battery, and I was able to get into the bootloader and select recovery, but the white HTC screen prevented me from entering CWR. I waited again, then pulled the plug, and then selected the factory reset option, but the same thing happened...
Now, the battery has died and it refuses to either charge / boot up entirely. I am at a loss. Any suggestions...?
The white HTC screen was frozen, so I got tired of waiting and pulled the battery. I was sure that I had done all the installation steps completely: run the super wipe file + install the rom. So i did a reboot and ended up waiting another 10 minutes for this thing to boot into the rom. I pulled the battery, and I was able to get into the bootloader and select recovery, but the white HTC screen prevented me from entering CWR. I waited again, then pulled the plug, and then selected the factory reset option, but the same thing happened...Now, the battery has died and it refuses to either charge / boot up entirely. I am at a loss. Any suggestions...?
