Help HELP! Phone Stuck in Odd Bootloop T__T
adk21589
This is the exact message I sent to adrynalyne that I thought I might share with you guys in hope for some further insight... Thanks guys :(
Dear adrynalyne,
I find myself very panicked and in need of your particular assistance. If you could take a moment to mull over my problem and give me some guidance, it would be greatly appreciated.
This is in regards to your DL09 back-to-stock .tar file for our fascinate. I used it on my phone a few days ago and it worked like a charm as I was returned fully back to stock. I then proceeded to get your fabulous EB01 rom on to my phone. (Thank you, by the way... you make this phone worth it)
The problem:
I just tried to get my girlfriends phone (which is almost identical in setup) back to stock flashing the same file and it's stuck in some odd bootloop!!! help!
The file flashes just fine in odin, but when it tries to proceed with the rest of the install through recovery, it keeps saying "data wipe failed" and then restarts, and then back to "data wipe failed" and so forth...
I am a fool.
Thanks for saving me guys. As dumb as it sounds, I mixed up the DL09 and DI01 stock flashes in some odd panic attack. Everything is back to good. :D
