Phone thinks its plugged in or trying to be plugged in, and the next second thinks it's being unplugged then thinks it's being plugged right back in. continues this madness untill my phone dies. I also got my service disconnected forgot to pay the bill
I have cleared everything no luck
reformatted no luck
flashed 3 different backups no luck
Plugged into my computer and safely removed hardware no luck
Plugged into wall charger no luck
Plugged into car charger no luck
Pulled battery no luck
reboot several times no luck
cleaned port with tooth brush and air duster
Help!:eviltongue:
.I have cleared everything no luck
reformatted no luck
Help!:eviltongue:
roud: I gave my mom my old LG Optimus S added a new line giving me a new "FREE" phone the Transform Ultra. I then swapped the phone numbers (giving her the new number and I kept my old number) and a family plan was created. My LINE (old #) was not up for the upgrade until September. :rock: Here is the best part, my line (old number) is still due for upgrade in September. My mom on the old phone but it's the new line/number isn't due to upgrade for the two years.
