Help Help!! Phone wont boot
jeepscx10
I successfully rooted my phone a couple months ago and have been experimenting with ROMs. I went and flashed the Undeniable Marquee ROM and it flashed successfully and when I went hit reboot it turned off came back on and went to LG logo screen and wont go any further and when it is off and i plug it in to my computer it goes to the same screen. Please help. What is wrong or what did i do wrong?
Thanks in advance,
Kenneth
You need to flash the CWM backup that you should have made. This will get you back to a functional phone. Then try flashing Megaron or CTMOD.
You could also just pull your sd card out and add a different ROM zip to it. Boot into CWM , do a factory reset, wipe cache and dalvik cache the go to.ADVANCED and then flash the new ROM.
Was able to get it to go to a screen that says "Download is in progress. Do not disconnect cable." and I tried to get into CWM and cant. Any suggestions?
Are you not able to get into any sort of recovery? If you're seeing that download screen, I'd imagine the firmware is trying to take an ota update. Which rom did you flash after rooting? Stock? Also, did you use rom manager at all? Lastly, are you sure the Rom you flashed was for the marquee and not the Optimus?
Please list the steps you took in rooting. Maybe you skipped a step or flashed a bad file. Without more information as to what led you there, there isn't a whole lot we can do
Sent from my LG-LG855 using Tapatalk 2
