Ok so I've read some threads but no one seems to have the same problem I'm having.
I have a Telus Galaxy Nexus running version 4.1.1 and it doesn't show that it is charging when i plug it in to the charger (I am using the same charger I've always used that came with the phone and tried other cables the have worked in the past) however when the phone is off the charging icon appears and the phone does charge. The problem is that when it turns on its a roll of the dice on how full the battery will be and it doesn't last long.
I have never done a software reset and if someone believes that will solve the issue then a link to a sep by step how to would be greatly appreciated. Ive had the phone since its release over a year ago.
Any help is appreciated
